RE: Methods to fuel proof firewall
Epoxy is exothermic, it generates heat as it starts to cure. The hotter it is, the faster it cures. If you are going to nuke it, do it in a wide container, so the epoxy has a good surface area to volume ratio, i.e., it's not a thick layer of epoxy. That will help keep the thermal reaction from getting into a runaway stage and smoking or melting out a container.
Jack
