ORIGINAL: mydartswinger
Part of the tension between heli pilots and plane pilots is that helis can get in the way of planes when they have an emergency or are just trying to take off and land due to the nature of flying helicopters (close in, largely over or near the runway). Another reason is that to many fixed wing pilots who are not around helicopters much, the large rotating main blades are very intimidating. Just the thought that one of those blades could theoretically break loose scares many of them. A propeller on an airplane, even the largest airplanes, are much smaller than the main rotor of anything over a a 400 sized helicopter. Plus the blades on a helicopter are held on by a small (in comparison) screw, while a prop is clamped down to the engine of a plane with 1-2 nuts, plus a washer, and usually a spinner with 2-4 screws. Even if the blades don't come off, they have a fear of getting their head chopped off (or at a minimum a large chunk of flesh taken off) by an out of control helicopter screaming into the pits (even more so with the larger helis). Many plane pilots also know that a helicopter is a complex machine (much more so than an airplane), and there is more to break. They also know that helicopters are more difficult to fly than a plane. As a helicopter pilot, their safety rests entirely in your hands while at the controls of your helicopter. As soon as you take to the air, they are relying on your setup and flying skills to keep them safe.
it might be because I started on helis but at a field I'm much more worried about someone crashing into me with their plane then their heli. But either way I don't want anything chasing me, heli or plane, I wouldn't stay at the field if there was a pilot being unsafe, but the club won't let people do that anyways so its not much of a problem.
one thing I wanted to add about complexity, I think planes are more complex, I'm talking about the hand built ones, the frames and construction of them is far more intrique then my heli, plane builders are true craftsmen to be able to scratch build a plane, with my helis if I crash I can always buy replacement parts, but with those balsa planes, you crash you buy or build a new kit
