RE: Boomerang Sprint Build Thread!
Hi,
As far as the retracts, it depends which ones you are going to use. Dreamworks has a set designed for the Sprint for $825.00 US Dollars. Todd is very good at what he does. That price includes everything inc 2/58" mains and a 2/14" nose wheel. As far as the tape on the elev, I talked to Bob Wilcox from Jet Cat on Monday and he said it's not a bad idea to put a strip on the leading edge of the stab. He said the problem occurs at the top end of the rpm's. If you want to talk to him, his number is 805-226-8700. He knows exactly the reasons. Be sure to protect the back end of the fuse and the turtle deck from the heat.
Doc...
