RCU Forums - View Single Post - I converted a glow engine to run on E85
Old 01-07-2009 | 09:25 PM
  #110
av8tor1977's Avatar
av8tor1977
Default RE: I converted a glow engine to run on E85
Methanol and oil is glow fuel without nitro.....
All you need to run no nitro, also called "FAI" fuel is higher compression ratios. It will run in low compression ratios engines, but not as well, and the idle, transition, and power will suffer.
AV8TOR
