RCU Forums - View Single Post - JEH Ignition
Thread: JEH Ignition
Old 06-05-2003 | 07:50 PM
av8tor1977's Avatar
av8tor1977
Default JEH Ignition
Sounds like you have a classic case of not enough dwell, about the only "downfall" you can get into with this system. You will find you will need to install more than one magnet. I have gone over this thoroughly with Jerry. With the one magnet, you do not have the coil "turned on" long enough for it to charge properly at higher rpm's. Here is a picture of how to easily figure it out.
Good luck,
AV8TOR
