RCU Forums - View Single Post - Problems with a Gyro
Old 03-21-2002 | 05:45 AM
sirrom
Default Problems with a Gyro
OK Gents need a little help here. The problem is as follows. I am setting up my JR 460T gyro on my bobcat. I installed it, plugged my rudder servos into it via a y cable and turned on the system. As the instructions said I let it set motionless for 3 seconds and it found it's center point. I then started setting up the high and low gain. Unfortunately when I go from low to high gain the setting the gyro resets it center position. I have called horizon and they are no help because I am using a futaba radio they won't help and great planes won't help because I am using a JR gyro. So I am stuck between a rock and a hard place.
So here are the facts:
JR 460T gyro
Futaba 9Z WC2 radio
Futaba 309DPS Receiver
JR Servos
Any help and suggestions welcomed.
Patrick.
