RE: Bud Nolsen Mr Mulligan
Well Bob, if it is the Bud Nolsen kit the 3 pages of instructions and the full scale plans are all you got to work with. Depending on what you are going to power the plane with and your style of flying you will have choices in how you tite you build to the plans. The plans call for a .060 motor and a gear drive. If you go up in motor size you will need to scale up support things like landing gear, fire wall,tail gear. The dowl pin system that hold on the wing are not to my liking either. I am incorporating wing tubes the run through the cabin and 1.5 feet in to the wing. I have also backed up the second fuse former with ply and will install 6, 1/4 inch dowels in a circular pattern through the firewall and former #1 and 2. I have changed the tail wheel setup also. If you would like to e-mail me for more info, I would be glad to help. Pm me here and give me your e-mail address as I don"t open e-mails from unknown addresses. Good luck with it.
