RCU Forums - View Single Post - How to Hover
Thread: How to Hover
Old 06-05-2003 | 02:46 PM
Luke 3D
Default How to Hover
make sure you stay as sharp as you can on the rudder.Try to keep the fuselage as vertical as you can. The more you do this, the easier it gets. The elevator is less critical, but if its windy you need to be sharp on the ailerons because the wind can get around the wing and make the plane roll . Then you end up with the bottom towards you which makes things tricky.
