RCU Forums - View Single Post - Helimax 400 3d
Old 01-09-2009 | 12:31 PM
  #90
electron's Avatar
electron
Default RE: Helimax 400 3d
I guess I am going to have to find a local heli guy to help me out as I still can't get my AXE 400 dialed in correctly.. I have to set the rudder sub trim to R 38 just to get the gyro to somewhat hold and for the gyro sensitivity on the radio if I turn it above like 20% it won't hold at all seems like the higher the number the less gain it has. I just wonder if that new trim pot you all have found has anything to do with this. There is one weird thing is I can't get the servo arm to be at 90 degrees on the tail servo as the splines are just wrong if I take it off and move it over a notch either way it’s too much the other way. I did notice with the subtrim setting at R 38 it makes the tail servo at 90 degrees, but then the tail pitch isn't neutral, but it is centered on the shaft if that makes sense...
Electron
