RCU Forums - View Single Post - AMR 50 Trainer
Old 01-09-2009 | 05:51 PM
  #62
king_arthur1953's Avatar
king_arthur1953
Default RE: AMR 50 Trainer
Well the weekend is finally here. Before I got started tonight I thought I would post some pics of the RSC SV-50 with the Bambula prop mounted and the standoff on the engine. I will have to replace the prop bolts that came with the engine. The prop is so thick at the that there are only about 2 threads in the hub. I also took a couple of pics of the 2 wing halves stuck together with the flaps and ailerons laid in place so you can get an idea of the size of this bird. This is as big a trainer as I have seen. Note: ignore the tuna can. Most of the ailerons were hanging off the table so I had to hold them in place with something.
Tonight I plan on adding the stringers to the bottom of the wings, adding the servo trays, installing the wire ways and building up the wing tips.
ID:	1107067   Click image for larger version
ID:	1107068   Click image for larger version
ID:	1107069   Click image for larger version
ID:	1107070   Click image for larger version
ID:	1107071   Click image for larger version
ID:	1107072   Click image for larger version
ID:	1107073   Click image for larger version
