RE: Tyco Fast Traxx
Well I am sure it is a common 370 can for the motor, but I doubt you gould get gears for it. I do not think you would need to, unless you are planning to slap a pair of 1/18 brushless systems in there. You would need at least a heli transmitter to get the proper stick configuration (2 stick throttles). Even then, I am not sure if both heli stick are spring loaded.
