BUILDING AND FLYING THE REACTOR 50CC. My friend in Dallas texas wrote the following info on his new REeactor 50cc Pics of plane and radio install are at the following link.
http://rides.webshots.com/album/569326871Hrubhw
I must say it is a fabulous aircraft that has not disappointed me in any way. I started with the reactors with a 40 size that I flew and still fly with a Saito 82. That aircraft amazes me every time I put it in the air. I am a fair pilot yet that plane does incredible tricks with great ease, so when I heard Great Plains was going to build a 50cc version I was anxiously waiting for it to arrive in my local hobby shop. I got the plane in late October and flew it for the first time a few weeks ago. The first flight was on a windy day that I should not have flown on. I was at the field flying my little reactor and decided to do some taxing with my big reactor to test the CG and its ground handling abilities “because if you have been around the little reactor they are awful on the ground with the rear swept gear and on the 40 size, you need to turn the gear around so they will taxi on a grass field” but on 50cc inverting the gear is little more difficult so I chose to test it first then modify it if the plane tends to nose over. Well they got it right on the big reactor so after a few quick passes I turned it into the wind and nailed it. The reactor jumps off the strip quickly and flies like a dream. This is one of the very few models that I ever flown and not had to trim it all. My first flight was just some circles around the field with some slow passes to test the stall speed and its reaction. After about 5 to 10 minutes I brought it around and landed it. The plane will just creep into a landing; it has to be one of the slowest landing planes I have. The next weekend I took it back out for more flights and have performed many tricks with the plane. It does the waterfall extremely well and is truly a dream to fly. So for me I couldn’t recommend a plane more than this one!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Here is a list of the stuff I put in the plane
1. 7 ea HS-7955-TG servos “all control surfaces”
2. 2 ea HS-85-MG “throttle and Choke”
3. 2ea 2600 Mah Li-ion “Receiver power”
4. 1ea 1600 mah Nimh “Ignition”
5. Da 50
6. 22x8 Mejzik carbon fiber prop
7. Eq6 Smartfly “primary reason for this is this board has servo matching which is a must for the dual servo per aileron + the power management for these high powered servos”
8. smartFly remote start switch
9. Smart Fly optical ignition switch
10. 3.5” Tru-turn spinner with the large prop cut out
11. Golden Rod for the throttle and choke
12. World Models Tail Gear with Spring shock absorber
13. 4-40 ball links on every control rod end
14. ¼ scale gauge set
15. Curios George Pilot
The only things I didn’t like about the kit were the instrument panel, tail gear and control horns. For the tail gear I replaced it with the world models gear and for the control horns I wanted to use ball links so a friend of mine “a master builder” suggested that I take two of the ones that come with the kit and mount them side by side with a ball link between them. So if you take two of the black horns and cut them off right through the mount screw holes then they are the perfect distance apart for a 4-40 ball link. It is a slick idea and it works great.
Mike/Dallas,Texas
