RCU Forums - View Single Post - Hydromites, yes two!
Old 01-10-2009 | 04:17 PM
Basstronics
Default Hydromites, yes two!
I decided in the fall I was going to build two Hydromites over the winter. I built one years back freehand. it turned out good but it never was finished. So here I am...
This time around I found out about Lazer Works that has "short kits" of the hydromite. Basically the woods precut except the larger sheets of square balsa/ply. Eddy got me my order in record time. http://lazer-works.com/list.html and its under $22 for the kit, well worth the $.
The power source is the same as Dr Jets small stuff. The 3000 KV small outrunner and the 30A Mystery ESC. I dont have a battery pack or rx picked out yet...
Heres some build pics:
This is the wood thats been laser cut.
Wood trimmed and sanded smooth on the edges:
The start of the skinning. Beware you need 1 right and 1 left!!!!
Next step, the small sponson former:
Small size issue. The slots not big enough for the thickness of the material. You need to sand towards the center. I used a needle file and was done quickly.
Assembled:
