ORIGINAL: plank420
dremal your piston. abmods is taking peoples money it is so easy to do.
Listen to this guy if you want to blow your engine, there is more into that than just do fancy cut, the real power is in the timing, you need to know what you do, and experiment a LOT to get those knowledge.
I have personaly worked with Adam for the OS28XZ drag mod and can tell you this engine have nothing to do with a stock one... dont be fooled by fancy cut on the sleeves, theres NO power there. The power is in the timing, only 0.3mm can make it go from WOW!! to
