[quote]ORIGINAL: kasarn
. Over has a video of a Modded truggy doing low 50's.
Stock Picco .28
In fact that vid is with the Drag modified OS28XZ, it did 54 mph on the stock 14T clutchbell only.
Heres a video of it:
http://s193.photobucket.com/albums/z...Bmods_drag.flv
That is a graph ^^ of a Clockwork Picco .28, dynoed by Abmods (dunno wich stage it is though) stock it is 1.9hp
The ABmods Drag modified Picco .28 is 2.31hp, it have slightly more bottom end punch than the OS28 , the OS28 have more top end and peak power.
Heres my run at 66mph:
http://www.youtube.com/watch?v=IaYVF5I2oIE
I had a small leak at the carb. had to run rich on bottom, making hard to clear up, thats why it sound weird on low rpm as, i lost times and room because of that to let the engine spool up higher. Im sure 67mph was possible.
I also had(still have) 2 broken a-arms that make it steer when on power, i had to counter steer to keep it straight...probably dont help too...
Good luck guys! ...might have to set the revo for top speed again if you beat me
