RE: no compression after sitting for 2 years
I'm pretty good with engines. It is narrowed down to the valve train. I took the cylinder/head off, filled it with fuel & watched it run out of the intake port within 10 seconds. So it''s not the pison ring. With the cylinder on I can cover the intake port & get compression.
I also have had some low compression engines run but this one will not. Could it be the springs?
