RCU Forums - View Single Post - E-flight apprentice
Old 01-10-2009 | 11:48 PM
w8ye's Avatar
w8ye
My Feedback: (16)
Default RE: E-flight apprentice
The wing is held to the plane by rubber bands
Are you talking about gluing the wing together? The wing has a front and rear plastic cap that are fastened to the wing halves with a contact tape to keep them from sliding off the wing tube. This should hold well enough.
you cannot charge your plane lipo battery directly with a 12v battery you must use a charger especially made for lipo batteries. But the charger might be able to run off your 12v battery
It says that the RTF comes with a charger that you attach to a 12v battery or power supply
3S Balancing Li-Po Charger (EFLC3010) (included)
For others reading this . . . . here is the manual
http://www.modelflight.com.au/manual...725-Manual.pdf
