RE: iwata airbrush
You may have some internal seals that are gummed up or worn out. I would completely disasseble it and soak the parts in lacquer thinner overnight. Blow out the passages with compressed air. If all else fails buy a Badger dual needle. I should have asked you if it's a siphon feed or gravity feed. Siphon feeds can be a-bit more troublesome.
Bill
