Tommie,
you might find these servos interesting:
http://www3.towerhobbies.com/cgi-bin...?&I=LXUDS3&P=7
I'd put one each of these on the ailerons and one each on rudder/elevator. You can use the servos you have for throttle or use those in the wings and a Hitec HS-55 on throttle. The HS-65HB's would also work nicely all around.
On the .23 powered Deception I'll be using 5 HS-65HB's (ailerons/main gear/elevator/rudder) and 2 HS-55's (throttle/nose gear). I may go with the digital version of the 65's on control surfaces (4 x HS-5065MG) if I can find them at a decent price.
Just some ideas...
David.
