RCU Forums - View Single Post - Servo Questions?
Old 01-11-2009 | 11:30 AM
TedMo
Default RE: Servo Questions?
What CG has said is most important. The decision on which arm to use depends mainly on the amount of throw required, as does the hole you select to use for linkage. The 4 hole arm will give you the most throw since it's longer therefore the distance it travels will be greater. Of course the hole location chosen on the control surface horn enters into this also.
