RE: Problems taking off?
I am supprised that the Tower Hobbies trainer does not have any right thrust built into the firewall.
Getting 2.5 degrees of right thrust was harder than it should of been because the engine mount is narrow and I had to file it down a little bit in order for the engine to be angled.
5 degrees seems like a lot. I will see how 2.5 goes and if it only improves a little then I will increase it.
The problem with going on the snow is that there are so many tracks from snowmobiles, skiers, vehicles, and who knows what else.
Josh,
