RCU Forums - View Single Post - Paint/Weathering Help
Old 01-11-2009 | 02:10 PM
googlydoogly
Default RE: Paint/Weathering Help
ORIGINAL: rva1945
Did you paint the fittings (hatches, levers, etc.) BEFORE glueing to the hull?
If so, how do you glue the fittings on the hull once it is covered in paint?
I glued everything first on the tank, then paint them. The only thing I didn't glue to the tank prior to painting are the tools, spare tracks, etc.
And if I need to glue things on the tank after painting, I simply glue them directly on to the paint. Even a small dab of glue is enough to hold everything in place. It's not as super-strong bond as a plastic-to-plastic bonding, but from my experience, gluing directly to the paint is more than enough to hold things in place.
In fact, there were times when I'm about to repaint a tank, that I sometimes have trouble removing some tools, even though I simply glued them directly on top of the paint.
