RE: DIY Loaded Voltmeter Help
Just place a 10 ohm 10 watt resistor in parallel with the meter probes for a 4 or 5 cell battery check, use a 22 ohm 10 watt resistor for the 8 cell battery. No need for a special loaded voltmeter as this does the exact same thing yet leaves your voltmeter available for other measurements.
