RE: Big Downthrust angle.
Dick:
I don't mind moving the thrust line up an amount. Basically it would help the design some by positioning the new glow motor closer on to the apparent centerline. This also increases the possibility of using a big propeller, but not by all that much.
If I go ahead and raise the glow engine some, will this eliminate some of the necessary downthrust, and will it enable the model to R.O.G. then?
Wm.
