RCU Forums - View Single Post - 10X/Spektrum module internally routed
Old 01-11-2009 | 10:17 PM
mndbndr3d
My Feedback: (12)
Default RE: 10X/Spektrum module internally routed
Dave,
How did you run the wire from the 2.4 antenna thru the ball base? did you drill a hole thru the aluminum adapter that came with the 2.4 conversion? how difficult is it to remove the 90deg connector from the wire?
do you have pics inside the Ball base antenna on where you routed the wire?
Harold.
