RCU Forums - View Single Post - Do you keep your sounds on
Old 01-12-2009 | 04:46 AM
borealis's Avatar
borealis
Default RE: Do you keep your sounds on
Usually yes. I turn it down just while testing something. The sound is also a good way to recognize a loss of signal between the tank and the transmitter (which in case of internal wire antenna is sometimes possible even at short range).
