RE: DIY Loaded Voltmeter Help
Reading through this interesting thread...it would seem that one could make up a number of "loads" that could be interchanged as the -to-be-measured-battery is selected. i.e. Blue one for receiver batteries; Red one for larger voltage TX batteries, etc. Is that right?
Just put the blue one on when you want to check the receiver; the red one on when you want to check the TX; etc. And leave the plug-in/plug-out "loads" off when you want to use the VOM for other purposes. ??? Rich
