RCU Forums - View Single Post - My plane is having issues
Old 01-12-2009 | 09:46 AM
draftman1's Avatar
draftman1
Default RE: My plane is having issues
if you had an impact, your clunk line is probably kinked inside the tank also. things like this can happen to any plane, wether its a spad or not. there are some tank set up tricks that help alot. keep on Spadden. as long as you have the CG right, your plane will fly good. also you need to make sure it is balance lateraly, wing tip to wing tip.
