RCU Forums - View Single Post - CDI/Engine will only Idle
Old 01-12-2009 | 10:36 AM
jerdavis's Avatar
jerdavis
Default RE: CDI/Engine will only Idle
mr,
You didn't mention if it ran the same on the ground, after the flight. If it is an inflight problem and you are using a Futaba PCM radio, and the RX battery is low, you could be seeing the RX going into battery Failsafe. Check the capacity of your Rx battery.
Jerry
