RCU Forums - View Single Post - CONVERTING KADET TO ELECTRIC - Project completed
Old 01-12-2009 | 11:29 AM
  #85
RCKen's Avatar
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: CONVERTING KADET TO ELECTRIC
mclina is correct, the switch is a component that you don't need. It could have a bad consequence if you plug in the ESC and the switch to the receiver is turned off. What could happen can vary from ESC to ESC, but can range from the prop turning on unexpectedly to the ESC burning out. I'd remove the switch. As was said above, the receiver is powered up when the battery is plugged in.
Ken
