DP Ultimate and Control Horns
The white tail horns came with bolts that fit through the surface and screw into the opposing horn (pull-pull) They send the back plates as extras I guess incase you forgo the set up that it is designed for. The bolts that were included seem to be fine and all the horns once attached work ok so far...
Jeff
