IT'S HERE YEAhhhhhhh.... My building board arrived today...
So first off... on the Elevator, should I bevel the LE before or after I insert the connecting rod??? I will be using CA hinges..
Any suggestions...
David,
I like the servos you showed me... the problem is in my budget... I will probeley get an hs55 for the throttle, use the tp 90's for the ailerons I have a towerhobbies standard I received for free that I will use for the elevator... and I may get a futaba s3114 for the rudder... what is your opinion of these servos...
Pics of the board.. It is the great planes 36 x 16 x 3/4..
Pic of the firewall and engine mount.. did that last knight could not wait....
pic of the elevater...
