ORIGINAL: Doc...
Hi,
Speaking of the P-80, do you have an exact location for the mount and where the Turbine needs to be in relationship to the engine compartment?
Doc...
with the eye rolling I'm not sure if you're trying to be a smartass or not but the turbine should be centered. in the pic above it appears that the 3/8 spacer required for the JetCat offset mount was not used (the turbine sits low of center), BUT it's of little importance in this setup, you can't burn a hole in a pipe that isn't there.
