RE: A warning to those using the crockpot cleaning method:
It's obvious you care about your little TD (I want one too). Go to fleabay and purchase the replacement aluminum carb body. You should anyway because the original plastic one was prone to cracking. I will do the same when I find a TD for something less than $90.00. If you're really digusted with your TD let me know what you want for it and I'll buy an aluminum carb housing.
Bill
