Thanks Chad for the picture
Yes , I think I'll use your method ( Simple and lite )
My Synergy should be done by the end of this month and I will be using a Asano Pipe and header.
I was having a bit of problems with my setup using G-Trick ,YS 120 FZ ,hatori header ( no header mount , nose ring yes ) kept cracking after 50 flights. Is this normal ??? I've read that others are also using this method with no problems.
Now I am using a Central Hobbies NMP header ( No problems with over 100 flight ) but this set-up is a bit noisier.
Any ideas ???
Well Success in Poland ( I studied in Canada in the eighties so my heart is still with you guys. ) When will there be a World C in Canada??
Thanks again
C LIm
www.Arubarcclub.com
