H Friends:
I have 1700, 2300 and 3000 (unstarted), but in the two first (with simjet electronics I change to Gaspar electronic) I had problems in the start, I changed the gas injector, because in the Simjet the gas flow into the camera for a 3mm stell tube and in opossite side that the plug and for me was dificult find the quantity of gas correct. I put one needle for thae gas and them the started was perfect, always. It is possible that I made anything bad, for this reason I need change the injectors, but now I no have more problems. I will open the 3000 for see the injector and change for the needle.
Regards from Spain.
Carlos.
_________________________________________
http://cmjets.blogspot.com/
