RCU Forums - View Single Post - Blade pitch differences???
Old 06-05-2003 | 05:26 PM
ARP35
Default Blade pitch differences???
Hi all,
I am setting up a Venture and was checking the pitch angle on the blades. I'm using a Helimax guage. The pitch angle on one blade is 2 or 3 degrees different then the other blade. The swashplate is level all around at 50% collective and the seesaw arms, etc are parallel. I did add some sub trim in the three ccpm servos to ensure the servo arms were straight, but no more than maybe 10 clicks. Do I physically remove one of the ball links off of one of the blades and adjust it so both blade pitch angles match? If so, do I remove the ball link that connects directly to the blade holder? Just wanted to make sure I do it right. The manual doesn't really explain it other than to say they should be close to matching. Thanks,
Alan
