RE: Throttle Cut on 9C
To get throttle cut for the second engine, you'll need a pmix. Set it to offset as master with throttle as slave. Put it on the same switch you're using for the throttle-cut feature and adjust the offset amount to get the throttle of the second engine to cut off.
