RE: TF Cessna 310 Inner Gear Doors
Epoxy a small hardwood pad to the inside of the wheel well near the bottom right up against the 45 deg. bend. The pad should be about as thick as the bell-crank bearing. It helps to pre drill a hole in it for a servo screw since its hard to work at the bottom (top) of the wheel well. I used a lighter to heat up a t-pin and pushed it through the fiberglass to make a starter hole.
