RE: The Integral.
Hi Guys
I bought an Integral last year not yet flown nearly ready to fly I to am having problems with the CG I have fitted a Ys 170 + short pipe rudder position as shown in the instuctions have put a few carbon tows in the under carrage postion as I have seen some that have cracked the fuz in that area the CF on mine is continuous from the under carrage past the fire wall to the nose ring the battery is fitted at the back of the tank support the CG in the instuctions does not seem to be correct other pilots say the CG is about 167mm from the front leading edge of the wing I will need to add weight at the tail not sure how much yet if a lot is required may consider having the rudder servo moved to the back end other Integrals fly well may be the construction in build is not quite correct
KFM
