RE: YS 170 Troubles
THen sound like you have a pump problem, the pump regulates transition and the idle on the 170, if you have played with the pump to the point where you can not lean it more, then you might have a problem with the pump plunger or plungers are not being able to close.
What about the smoke from the engine, how is it at idle mid anf full power?
