RE: Thrust to weight
The rule is about as good as it gets
the problem is how much power does it take to lift a given weight
the prop used is simply the tool which has to covert power into thrust
and there are a number of props which will do this .
2/3/4/blades will all work but generally speaking , max diameter which is pitched such that the engine produces max power -is the best combo.
