RE: Suggestions for L-4 Cub motor
Dirtrod
Did you have to cut out some of the fuselage to mount your motor sideways. With the FS 90 I have I would need to do that and then the gas tank is to low. The carb on the FS 90 is mounted on the side instead of being centered on the jug. Which means I would have to try and raise the gas tank outlet up to match the spray bar. One other ?, would you have the measurements of the firewall for the thrust lines.
Terrell
