ORIGINAL: cat samich
hey here is a thought on what to do about gearing. take a dremel with a cut off wheel and cut the pilot shaft off of the axial. then buy a clutch nut that has a pilot shaft. if you buy the right clutch nut you can run the traxxas clutch bells on the big block. i used traxxas clutches with my hyper .21 converted maxx
Yeah i thought of that. I am going to try my best to keep my new engine itact. Traxxas makes spacers and clutch nuts for big blocks. I order them already. They should be in today.
