RCU Forums - View Single Post - How to adjust adjustable diff for FG?
Old 01-15-2009 | 04:00 PM
pwaicon
Default RE: How to adjust adjustable diff for FG?
If you assembled the LSD per FG’s instruction sheet the screw that is for the tension also has another screw next to it that holds on the diff sleeve. Here is a link to FG’s LDS instruction sheet. I hope it helps and good luck. [link]http://www.fg-modellsport-gmbh.de/_PDF-ANLEITUNGEN/A.08485-05.pdf[/link]
