RE: Suggestions for L-4 Cub motor
Terrell,
On mine i had to dremel a spot on the side just for the intake mabey 1/4 not much.
on mine it called for a 1/4 inch plate on the firewall but with the 4-stroke it is not needed.
I will check on those measurments i have the plans and the instruction man.If you
use the .90 you wont put your bat and rec under tank so i rase it up with some styro.
I will get back to you with those measurments. What cub is it ,the anniversery addition?
Ty
