RE: Suggestions for L-4 Cub motor
Terrell,
there is no real measurment to give you the way it shows you mount the top motormount
basically all the way to the top and then hold the bottom one up to the motor and mark the holes.
It might be about a 1/8th in from the top you will need to put a small washer on the left bolts
for some right thrust . just one on each left bolt.Are you useing a two piece mount?
Ty
