RCU Forums - View Single Post - Need Some Advice
Old 01-15-2009 | 08:31 PM
DustinB's Avatar
DustinB
Default RE: Need Some Advice
Started building my order based on the comments(thank you). This is what I came up with.
Qty - Tower Part# - Description
________________________________________________
1x - LXFMD5 - OS 46AX ABL 40G Carb
1x - LXCAS2 - Tower Trainer 40 MkII ARF
1x - LXSFY3 - Futaba 6EX 2.4GHz w/4 S3004 Servos
1x - LXPT38 - 2oz CA Thin Glue
1x - LXPT47 - 30 Minute Epoxy 4oz
1x - LXL287 - Hobbico Extension 6" Futaba J
3x - LXZ971 - Master Airscrew 11x6 G3 Nylon Prop
1x - LXL387 - Hobbico 4-Way Wrench
2x - LXCB26 - OS A3 Glow Plug Hot
1x - LXL405 - Hobbico Starter Stick
1x - LXJUJ6 - Tower AA Slim Glow Starter
2x - LXRXC4 - Tower Power 10% Fuel Quart
1x - LXFAW2 - Tower Hand-Crank Fuel Pump
$539.41
Is there anything not needed, anything I missed, or anything that should be changed? I want to get everything needed to build and fly. Didn't know if I needed fuel line or anything else.
Thanks for the replies,
Dustin
