RCU Forums - View Single Post - reciever pack charging
Old 01-16-2009 | 02:54 PM
huminski's Avatar
huminski
My Feedback: (23)
Default RE: reciever pack charging
There is a chance, albeit slight, of nickel cells exploding if left to overcharge long enough at a high enough amperage.
I stand by what I said. If it's a wall wart that says on the casing OUTPUT: 7.2V, 1.2A, then it will be fine. Of course it will have to be monitored / timed especially at that charge rate.
If it's a charger designed for a 7.2v pack, then no, do not use it, because the output voltage is likely upwards of 8 or 9 volts.
If you have a cordless drill, take a look at the charger. For example, I have a 24V drill, the charger puts out 28V. My 14.4V craftsman
charger puts out 18V.
