ORIGINAL: samguan
RCtruckRacer thx for the reply.
So are you saying that the output anywhere between 11V-18V is fine right? and the A can be as high as you want right? if the charger says 5A, that means the minimum right??
That is correct. The 19.5 volt may work if the charger doesn't go into error. My guess is that it won't.
